And it was all going so well....
I finally got the lathe bolted down over the weekend, what with my wife bing 7 months pregnant now and being busy last few months with commissions and a rather unfortunate event where for an unknown reason my body decided that it didnt want to be upright and promptly passed out while in the loo early one morning, properly faceplanted onto the stone tiled floor, bit through my lip and wife called ambulance, which is what you want at 5am. fortunately nothing wrong, just seen as either low blood pressure from early AM just stabding up, or it can happen when you go for morning loo visit!!
So decided not to operate sharp tools and high speed machinery for a bit.
First quiet day for a bit between commissions so i started playing about with some new techniques, and...it didnt go well.
I wanted to try and make a small goblet going by the instructions in Keith Rowleys book, mainly hollowing out on spare blocks to get a feel for it, and after 3 attempts i was about ready to set my shed on fire.
I did secure my lathe down to the desk:
20190923_122057 by
Richard Rose, on Flickr
First failure was my own fault and i knew what happened, using a small 3/8" spindle gouge i was carefully removing material but after a bit i think the trailing edge of the profile caught the side wall at the edge and the piece working on came right off the machine, i think the scroll chuck doesnt grip strongly enough and pieces can move out under jerks\catches.
20190923_121639 by
20190923_121628 by
Richard Rose, on Flickr GONE!
So i cut off the waste and made another attempt, this time using my 3/8" bowl gouge, which i made into a more high winged grind from the standard factory setup. This i was being very cagey with as its a bigger tool (diamater of the tool compared with the spindle gouge) and i was wary of digging in and parts flying!
20190923_121508 by
This time i screwed the wood onto the faceplate to get a stronger hold for working. The tool was working okay, i was making sure not to present at 90' to the tool rest and make sure the lower left of the cutting edge from the tip was cutting and not the wing so moving the tool handle away from my as i came up the side wall while hollowing (if that makes sense).
However after a bit it must have caught again and the whole thing (only a cylinder about 4" long and 3" wide so nothing big!) ripped off the faceplate and at that point i gave it up as a bad job.
20190923_121652 by
20190923_121658 by
Examples of the drama:
The main issue i have is, there isnt any local turning groups around here (nearest is about an hour away) and yout tube vids and reading can only show you so much.
I realise this is only my first attempts at hollowing, but for both time to result in cathcing and rippping the wood from the lathe, its not filling me with confidence.
On the plus side, i was able to turn out a sharper looking new type of xmas tree using the scroll chuck jaws holding the piece and parted it off safely with parting tool
so not all bad.
I will keep working away and maybe the smaller diameter hollowing out is actually harder than a bowl blank that has more space to work and less acute angles. Dunno
