Karim Sleiman
- Joined
- 20 Mar 2023
- Messages
- 21
- Reaction score
- 0
- Hardwood Edge Banding:
- Made from one continuous piece of solid oak wood.
- Features a small lip on top (male part), 2.5 mm in size.
- Measures 30 cm in diameter.
- Edges are 6 mm wide x 16 mm depth.
- Female Part:
- Made from fibracolour or valchromat.
- Thickness is 19 mm.
- Includes a lip on the bottom to accommodate a 3 mm difference.
- Provides a decorative line border.
- Concerns:
- Potential issue with gluing the oak hardwood edge banding to the sides and bottom.
- Consideration of wood movement, which might affect the bonding or fit over time.
also in the pic number 5 would inlaying solid oak wood measuring 6mmx6mm be a concern i can use thin veneered mdf instead. I would prefer the uniform look of solid wood to match the border. and usually what is veneered on one side should be veneered on the other does this apply to pic number 5 or it only counts if the whole face is veneered in this case its inlayed but sort of the same i guess not sure .Thank you all
