Hegner Scroll Saw advice
Thanks guys.
It's not quite perfect as there are a few spots where the edges needed sanding to smooth them out a bit where I had gone slightly off line.
However I enjoyed doing it, and hopefully I will get more accurate with time and practice.
Onwards and upwards.... :)
To paraphrase an old saying, "The lines aren't written in stone." I soon learned that only the scroll saw operator knows if s/he wandered off the line. Although I still mention it sometimes. :)
Martin.
****UPDATE*****
Since I made this post I have not used the saw as much as I would like due to not having much spare time but also mainly because I was not 100% happy with the saw due to the fault.
Anyway last weekend I decided to order a new C-Frame for the saw which came to around £100 with postage. :cry:
The C-Frame arrived today via Fed-ex and I bunked off work early to fit the new C-Frame and try the saw out.
Result! The saw is now transformed, it is quieter in operation and the blade now runs straight and true.
Hopefully I can now get on and practice, practice, practice and give the saw some use. :D
Good to see the problems with your saw appear to be sorted.
Happy scroll sawing, make some sawdust. :wink:
Take care.
Chris R,
