Hegner Multi Cut 1?
Hugh M.
25 Oct 2024
UK
I thought recently that I don’t use my scroll saw enough. It was a second hand purchase that I thought I could use to produce knife scales. It wasn’t great at that and a bandsaw was duly acquired.
I think it is a Multi Cut 1:
I’m assuming the 1 refers to the number of speeds? What I really want to know is, is there an after market blade thing? Here’s what I have:
A tool that you use to undo a clamp held in the little recess on the bottom right corner. I find juggling with the workpiece, the tool and blade whilst trying to keep everything straight is a chore.
Maybe I just need more practice? TIA.
@scrimper is the expert on Hegner scroll saws.
However, looking at your scroll saw it looks like a Multicut 1. The 1 refers to the model range 1=Entry Level, 2=Mid Range. The one does not refer to the number of speeds - for example the Milticut 2 is available in single and variable speed.
You can find a page on Hegner scroll saws on Scrimper’s website: https://sites.google.com/view/scrimpers-fretworking-site/fretsaws/hegner-saws
You may wish to consider using a Quick Clamp for quick release of the blade: https://www.hegner.co.uk/hegner/hm0450.html
Hope the above helps.
Thanks, that does help.
Great. I have recently purchased a second hand Hegner Multicut 2S Variable Speed and am still learning the ropes. If you have any other questions I can attempt to answer them.
One thing I have found is if you push the blade into the blade holder so it touches the locking screw the blade moves when the screw is tightened and the blade is not straight to the direction of cut. If you move the blade out a fraction and then tighten, the blade tends to remain straight. Hope that makes sense.
Many thanks for recommending my website. I think you do exaggerate on my knowledge on Hegner though- but thank you for the compliment.
I agree with your comment on the use of the Quick clamp - in my opinion it's essential and improves the cutting experience massively.
I agree 100% about the blade touching the locking screw that is exactly correct. :)
I hope you enjoy using your Hegner they are a brilliant machine - even after 25 years of use I still love using mine, it is my favourite machine to use in my workshop - quiet and gentle to use compare to all the other noisy machines I use. :)
Hugh am I right in thinking you have a Coronet major? It very much looks like one poking it's 'nose' into your images above. I have the one shown below which I bought new in 1976. I had wanted one since I was a lad after seeing them advertised in the DIY magazines in the 1960's. They are a superbly made machine but lost out when stand alone far east made cheap machines became available.
I see that Lamb has answered your question admirably - may I suggest that you remove the hold down tool and guard thing completely, they serve no useful purpose and make the saw much more fiddly to use. :)
