RichardG
If at first you don’t succeed have a cup of tea.
I'm looking at various options of installing Solar Panels. Unfortunately none of our roofs face South and the only usable one due to shading etc. is on the workshop which is West facing and not too large, looks like we can get 10 panels on easily or perhaps 12 panels at a squeeze. However, we have 2 acres to play with so a potential solution is a ground mount which could be installed with all the optimum angles to maximise output plus it would also allow for easy cleaning and maintenance.
Commercial offerings for 16 panels are £1500+ and you still need to lay the foundations and then assemble and install. It looks like a straight forward job to build one from scratch either in wood or using scaffolding but I think it will need planning permission, not sure about building control? There's also the matter of snow and wind loading so may need structural engineering sign off?
Just wondered if anyone had been down this route and can share their experience?
Richard
Richard
