ciscoeuk":2hiumm3x said:Aled Dafis":2hiumm3x said:Google is your friend
ROHS - The Restriction of the Use of Certain Hazardous Substances
http://www.rohs.gov.uk/Docs/Links/RoHS Regs Guidance - 21 June 2006.pdf
Basically it looks like you'd need the machines with ROHS.
Aled
rohs only comes into play if you are a comercial vernture, all machines, must be CE certifide which is a minimum code for europe
Quick google says not:
Can I import for own use?
No, the EC's 'Guide to the implementation of directives based on the New Approach and the Global Approach' (the 'blue book') available at http://ec.europa.eu/enterprise/newappro ... 282_en.pdf states note (30) in the side bar of page 18 under note (30) “Thus, imports for own use are also considered placed on the market…”. Therefore it is our view that EEE imported into the EU for own use even from another branch of the same organisation outside the EU must comply.
(from http://www.rohs.gov.uk/FAQs.aspx#10)
