bourbon
and remember, your missus will get you 20% off at screwfix for any tools
but if you do - cheapo steel cutlery may fit if the handles are thin enough. Just been painting a door with the handles and hardware off, but a fork on one side and a spoon in the other - jammed in handles first, work fine to turn the latch. Might just leave them there, who needs knobs!..... ( dont close the door unless youve fitted the handles ) ....
Ages ago, i had some spare spindles hanging about and welded 2 together in a T shape. I keep it in my pocket, so if a door blows shut of i close it without thinking, ive got a quick easy way to open it againbut if you do - cheapo steel cutlery may fit if the handles are thin enough. Just been painting a door with the handles and hardware off, but a fork on one side and a spoon in the other - jammed in handles first, work fine to turn the latch. Might just leave them there, who needs knobs!
To give yourself a fighting chance.....
Start by checking your levels are in fact level in all bubbles and your square / squares are truly square.
Get each level and place it against a flat surface ( horizontal and vertical need to be checked )
Look carefully at the bubble placement, then rotate the level round 180°, keeping the vial in the same location ( i.e dont spin it end to end, just rotate it ) then recheck the bubble carefully. If the bubble is in a different location, its not level.
Put your square against a properly flat edge, mark along the square. Spin the square over 180° and hold it against your line. If they dont line up properly, it isnt square.
Now the linings.... start on the hanging side. Check it for level.... i mean really check it. Take in any bow in the frame, look across it's face from one edge to the other from top to bottom to check it isnt twisting. If its good, check the head for level and hold your square against it for good measure. If its out, make a note of how much and which way. I.e if it rises towards the latch side, you need to allow for trimming that when you mark your hinges.
Now measure the width, top, middle and bottom. If its equal and the latch side isnt twisting etc, you need to bone the lining.
No, i dont mean rub yourself against it
Stand offset to the lining so you can eye through the leading edge of one side to the back edge of the other ( like in my photo, excuse the mess )
This shows if the door is likely to sit flush along the closing edge of the latch side, or if it'll stick out top or bottom.
Hopefully now you know what the lining is like and what needs trimming.
Assuming youve made any relevant allowance on the head if its out of level, next you mark your hinges.
Normally we measure 6" down from the top of the door and 9"up from bottom and i centre any middle hinges between the other 2.
If your linings already have hinge recesses, match those on your door. If not, cut the door ones, check your measures, then transfer to the lining, adding 3mm gap at the top. I.e a 150mm hinge position on door means 153mm down from head of lining.
Cut them out. Mark the screw holes and predrill 1 screw hole in each hinge. Try it for size, fixing off the first screw in each hinge. It worked? Great, drill out the other screw positions and fix it off. If not, at least you only have 1 hole in the wrong place on each hinge and not all 4!
I have lots of wedges around and i usually put a pair of wedges under each side of the door and lift the door to height using the wedges, so you aren't fighting to align a door and screw it home at the same time.
Packers are fab for aligning too.
I use the trend lock jig to make the hole for the latch but to get the depth you need a big 1/2 router to get down 70 mm.
@Doug71 Only yesterday, I discovered the Robin Clevett jig doesn't work on linings without stop fitted but with architrave fitted, but I guess that's obvious if you think about it. Just saying.@Mark65 it says the Robin Clevett jig works on linings without the stops fitted but you say you have casings so it would only work for the hinge cut outs on your doors.
For the few you have to do I would just mark around the hinge with a Stanley knife, chisel the cut line a bit deeper then route out to within a couple of mill of that line. It helps to use a bit of MDF or similar to pack out the rebates in the casings to run the router on.
Hi, I didn't think that jig will work after a closer look, I may just free hand it and finish with chisels, or look for a smaller jig, the wife says try someone else but I'm getting tired of the messing, as two doors have handles and hinges and gives I would think it would be a day rate job, about £250. I'm still planning on having a go though.
