I'd add a pair of winding sticks to that, to show up any twist.custard":290p8zz1 said:The critical piece of kit is a decent long straight edge
Your Kiwi cousins call a planer a buzzer *, and a thicknesser just that. But then we're probably weird too (but never as weird has those Yanks (hammer) ).fluffflinger":l6swz1yg said:...to avoid confusion remember our American Cousins call a thicknesser a planer and a planer a jointer, weird!!!
matthewwh":1x6ajnwg said:Just a quick one to add if you're not used to using a lunchbox toaster.
It sounds obvious, but make sure you set it for the thickest part of the board and work down from there. When leveling boards it's really easy to feed them the thin end of a wedge and end up with the board stuck in the machine - disassembly of the machine is the only way out.
If you read any texts from the 1950s you'll find that we used to call a thicknesser a "panel planer" and the term "jointer" was in common use, alongside "overhand planer". It's our language which has changedfluffflinger":14uavnrf said:Just watched the video and to avoid confusion remember our American Cousins call a thicknesser a planer and a planer a jointer, weird!!!
Paddy Roxburgh":1tvux5uy said:Matthew, I have only used 3 phase under over machines at work but am thinking of getting a "lunchbox" (or toaster" for my shed at home. When I get a piece stuck in my thicknesser at work I just lower the bed and take it out. I can see that the little hobby thicknessers work by the cutter not the bed moving,does this mean I can't just raise the cutter if I get a piece stuck? Disassembly sounds like a PITA. I have a little inca 8" planer at home but in light of what you've said I may ebay it and by a cheap under over for the shed.
Sorry if this questio should be in a different part of the forum as this is veering away from a hand tool discussion.
Paddy
