I had a similar problem and the Y-lever plus the pin were worn out, replacement with a set from Workshop Heaven fixed the problem. Cap iron placement I just set it as close as I can until I get accordion shavings and then back it off a touch probably about 0.4-0.5 mm total, thicker shavings will mean you have to increase the gap but it is very much wood and user dependent.
