Pekka Huhta
It is easier to clean up the waste if you don't even try to cut it parallel to the bottom of the joint.
.... unless you saw a series of kerfs first.
Sure
Sawing may be handy sometimes (it also helps to level the bottom of the joint), but in many cases I think it can be easily avoided with this trick.
The best world of both is to saw the kerfs and use a slicing cut, but I'm a lazy man and have learned to avoid the kerfs this way. It's just extra work sawing them if you can cut the joint without.
Most of the work I do is less demanding than hi-end furniture from exotic woods, so I do skip extra work phases as much as possible. In fact I got the inspiration of showing that trick from a pair of small rafter frames (?) I just made a few days ago for a small canopy over a front door.
That's pretty far from fine furniture :wink: As I use a lot of softwoods and my techniques are closer to timber framing than furniture carpentry, I have a bit of a different approach.
I don't even know if that trick could be used with hard and gnarly exotic woods, probably the kerfs are much better approach for them. But for softer woods that works fine.
Pekka
