Before I write anything else I should state that I own a Prius. Now that's out in the open...
Back to the original post from Jenx, and not getting involved in the global warming debate...
Jenx":2b2dwjoc said:
Having heard it rumoured many times.. was doing a bit of research...
"The Prius is powered by not one, but two engines: a standard 76 horsepower, 1.5-liter gas engine found in most cars today and a battery- powered engine that deals out 67 horsepower and a whooping 295ft/lbs of torque, below 2000 revolutions per minute. "
It has a standard engine and an electric
motor, but that's not hugely relevant.
Essentially, the Toyota Synergy Drive system, as it is so called, propels the car from a dead stop to up to 30mph.
Not necessarily true - it depends entirely on the driving conditions. You can get up to more than 30 on electric, sometimes the engine comes on sooner.
The battery is recharged through the braking system, as well as when the gasoline engine takes over anywhere north of 30mph.
The battery is also recharged when coasting into a junction and when travelling down hill.
It isn't always charged when the engine takes over - again, it varies according to conditions and driving style.
You would be right if you went by the old government EPA estimates, which netted the Prius an incredible 60 miles per gallon in the city and 51 miles per gallon on the highway. Unfortunately for Toyota, the government realized how unrealistic their EPA tests were, which consisted of highway speeds limited to 55mph and acceleration of only 3.3 mph per second. The new tests which affect all 2008 models give a much more realistic rating with highway speeds of 80mph and acceleration of 8mph per second. This has dropped the Prius EPA down by 25 percent to an average of 45mpg. This now puts the Toyota within spitting distance of cars like the Chevy Aveo, which costs less then half what the Prius costs.
My usual mpg is around 55, and I know that is lower than a lot of people who drive Priuses. Occasionally I get mid 60s. The car is not designed to drive at 80mph and shouldn't be going over 70. I find that my most economic speed is around 50 mph.
However, if that was the only issue with the Prius, I wouldn't be writing this article. It gets much worse.
Building a Toyota Prius causes more environmental damage than a Hummer that is on the road for three times longer than a Prius. As already noted, the Prius is partly driven by a battery which contains nickel. The nickel is mined and smelted at a plant in Sudbury, Ontario. This plant has caused so much environmental damage to the surrounding environment that NASA has used the dead zone around the plant to test moon rovers. The area around the plant is devoid of any life for miles.
NASA hasn't actually used Sudbury for training since the early 70s and when it did it was because of the rock formations caused by an ancient meteor strike, not because of mining destruction.
The plant is the source of all the nickel found in a Prius battery and Toyota purchases 1,000 tons annually. Dubbed the Superstack, the plague-factory has spread sulfur dioxide across northern Ontario, becoming every environmentalists nightmare.
The acid rain around Sudbury was so bad it destroyed all the plants and the soil slid down off the hillside, said Canadian Greenpeace energy-coordinator David Martin during an interview with Mail, a British-based newspaper.
There are several sources online (eg.
here and
here) which shed a little more light on the nickel issue. One quote is
"Out of the Inco mine’s 174,800-ton output in 2004, Toyota purchased 1000 tons, just over a half-percent of its output".
Both links which I gave report that the article describes Sudbury in the 1970s, before Toyota was making the Prius and before large clean-up operations.
All of this would be bad enough in and of itself; however, the journey to make a hybrid doesn't end there. The nickel produced by this disastrous plant is shipped via massive container ship to the largest nickel refinery in Europe. From there, the nickel hops over to China to produce nickel foam. From there, it goes to Japan. Finally, the completed batteries are shipped to the United States, finalizing the around-the-world trip required to produce a single Prius battery.
Yes, this is crazy.
Through a study by CNW Marketing called “Dust to Dust," the total combined energy is taken from all the electrical, fuel, transportation, materials (metal, plastic, etc) and hundreds of other factors over the expected lifetime of a vehicle. The Prius costs an average of $3.25 per mile driven over a lifetime of 100,000 miles - the expected lifespan of the Hybrid.
Having just skimmed through the "Dust to Dust" document I found the following statement
One thing is clear. The typical hybrid small vehicle such as the Prius is driven far fewer miles
each year than a comparably sized budget car. And for good reason. Like Upper Premium Sports
cars, these are generally secondary vehicles in a household OR they are driven in restricted or
short range environments such as college campuses or retirement neighborhoods. Clearly both of
those are generalizations and there are exceptions, but nonetheless this is a reality of automotive
use.
This is a ridiculous assumption and I would suggest that this is actually the exception to the norm. The original report is from the US though, so maybe their Prius ownership is that much different from ours.
Through a study by CNW Marketing called “Dust to Dust," the total combined energy is taken from all the electrical, fuel, transportation, materials (metal, plastic, etc) and hundreds of other factors over the expected lifetime of a vehicle. The Prius costs an average of $3.25 per mile driven over a lifetime of 100,000 miles - the expected lifespan of the Hybrid.The Hummer, on the other hand, costs a more fiscal $1.95 per mile to put on the road over an expected lifetime of 300,000 miles. That means the Hummer will last three times longer than a Prius and use less combined energy doing it.
The "Dust to Dust" report assumes that the Prius and other hybrids will have an expected lifetime of 10 years. The first Prius was launched in 1997 and according to
Wikipedia this model is now being exported and sold second hand. (admittedly this could be false data, but there is a link to completed sales for 1997 models)
This suggests a reliable vehicle.
Of course, the information that I found against the original "Dust to Dust" report is all online and I can't say for sure that they weren't written by either hybrid owners or people with a green agenda.
When it comes down to it, I didn't buy a Prius because I thought it was greener, although it was a small factor, and I didn't buy because of the fuel economy, although that was a larger factor. The main reason was that I went for a test drive just out of interest and loved the driving experience.
Right, you can now carry on discussing global warming ;-)
Duncan
