Richard Findley
Hi all,
I had a commission this week from a lady that was after some large Oak Balls to top off some Gateposts. They needed to be somewhere in the region of 5 1/2" to 6" diamiter and so I went through all of the possible options for her, either laminate several pieces of say 2" Oak to make up the required size, try to find some large Oak posts we could chop up and use or get some logs and use Green Oak for them. Straight away she went for the Green Oak option so I contacted our friend George (Cornucopia) as I knew he's the man for logs of Green Oak.
George said he didn't have any but was planning to get some soon so he called into his friendly log supplier and stocked himself up and ear-marked a log for me too!! (see his pictures in his thread: https://www.ukworkshop.co.uk/forums/from-woodland-to-lathe-an-oaks-journey-t40768.html)
After a visit to George's I went home with a large block of Oak:
As you can see it's about 8" square and 18" long!! I wasn't sure what my Bandsaw would think of this chunck of wood as it's the biggest bit I'd put through it but it cut it with ease!!:
Probably couldn't get a much bigger bit through the throat though!!
I dodn't usually bother taking the corners off of spindle blanks but as this was so big I did:
Out of interest I checked the moisture with my meter, 40.7 so I knew I was going to get wet !!
I hate turning Green Wood!!! I know that there are a number of guys that love it and hate turning kiln dried stuff but I really can't see the appeal. Everything cast Iron in the workshop got a liberal covering of WD40 before I began because I've fell for that one before, even so, all of my tools turned black, as did my hands and the tool rest dispite the WD40. There was water running down the flute of the gouge for goodness sake :roll: :roll: :shock: :shock: !!!
I held the blanks between centres and turned most of the ball. I'd cut an MDF template to give me a reference.
Once I was happy with the shape I drilled a 12mm hole in the end and rotated the ball and held it between wooden blocks:
Using a shearing cut with the wing of the gouge I smoothed it out. A couple more mountings just to be certain:
And there you have it!! The advantage of the Green Oak was that it cuts quite nicely, sometimes the cuts on the ball when it is rotated can tear the grain but on this the finish off the tool was pretty good. Sanded with 80grit.
I then Epoxied some 12mm Stainless Steel Threaded rod into the holes:
Hey Presto:
Finished with some finishing oil to help preserve them out doors!!
Hope you enjoyed the WIP. Any comments welcome as always.
Richard
Hey Presto:
Richard
