Reggie
I ordered one of those axminster no.5s on Wednesday and it turned up today, it did indeed need some fettling but nothing too heavy, the first thing I did was to just check the overall finish of the item no pits or marks in the sole, no errors in the casting, the mouth is nice and straight, finish on the handle is functional, looks like whatever they used pooled on the side of the handle but it doesn't detract from the usefulness of the plane :-D
Next up was to check the yoke, I ran the adjuster from front to back and it had a tendency to try and ride out of the groove, this will lead to inconsistency when trying to adjust the blade or worse still, popping out of the groove and leaving the blade too proud or too far back in the plane mouth to be effective.
The only way to fix that was to make the 2 ends of the yoke closer together, I took the frog off, the screws came off nicely so no threading there, got my pliers and a cloth to stop them from marking and gently squeezed the ends of the yoke until the were sufficiently close, put it all back together and now the adjuster action is consistent from front to back.
next up was the blade, not sure if it's just me but the blade seems fairly thin and short too, I'll check it tomorrow against the record blade, it seemed like it was bit flexible. I gave it a quick 25deg touch up/hone and then put a small 2ndary 30 degree bevel, put the plane back together and tested, the chipbreaker immediately jammed up with bits, I checked it against the light and there was a clear gap between the end of the breaker and the back of the blade, it was only touching on the back edge of the end of the breaker, it needed a reasonable amount of work to get it back to touching at the front but once it was done, I tested again and got nice thin easy shavings on the first push
I am incredibly happy with my purchase, I checked the flatness of the sole of the plane and it looked much less than 0.5mm, although it's possible I need a better straight edge to check it with, either way it shouldn't take very much at all to lap the sole and get it completely flat.
I also purchase a pair of axminster scrollsaw blade clamps at £2 each, they're cheap cast iron but they don't need to be pretty, they just need to work, pretty simple to fit, they just replace what's there and use the existing bolt to fix them to the saw arms. I wanted blade clamps because the pinned blades aren't very good for intricate inside work, you need a 5-6mm hole to fit the pins through, with the clamps fitted i can use pinless blades and the size of the hole needed is the width of the blade (2mm or less I think), I only tested the scrollsaw for 10 seconds but the small cut I made was clean and vertical, I didn't need any compensation for left/right swerve on the blade, the blade stayed in and didn't snap, so for now it looks like another good cheap purchase from axminster
