Phil Pascoe
(( wouldn't the arc differ only in length? the two sides are parallel.
Yes. The radius of both sides of the gouge (assuming constant thickness) is the same.xy mosian":3tapcz6i said:Thinking back to the running track. The radius of the curve changes, from inside to outside, by eight track widths. If the inner and outer track radii were the same then the straights would have no track widths. In my head anyway.
xy
Yep, I'd agree; difficult and time consuming but not impossible. I've turned a number of out cannel's into scribing gouges by using a small grey conical grinding wheel in a Proxxon mini drill. Square off the end first of all and then start grinding; takes an hour+custard":2dxmt2ir said:Going from in-cannel to out-cannel isn't too arduous with a power grinding wheel or linisher, it's no different to re-profiling a turning gouge. But going the opposite direction would be a nightmare!
Woody2Shoes":2tu0119y said:Two very good sources of info. - one from a carver (the excellent Chris Pye), and one from Paul Sellers:
http://woodcarvingillustrated.com/blog/ ... our-tools/
https://www.youtube.com/watch?v=m-Dy7R8xQBM
Looking forward to seeing the reults!
