MikeG.
I've never owned a gouge, and I'm about to buy one or more. I could do with some advice. I want larger sized gouges for carving thumbnails.Around an inch is ideal. Quite a number that I see on the bay are in cannel, though, and I obviously need out cannel. I realise that there is quite a lot of steel to remove in regrinding from in to out, so I was just after a bit of advice from those who may have done this. My instinct is to square off the end first, which will never leave me grinding thin steel (other than right at the start), and then grind the cannel the other side. Is this how I should do it, or should I set up to grind the out cannel right from the start of the process?
