If I decide to use Iroko for my window project will I have problems gluing it? Reading around it suggests wiping the surfaces to be glued with acetone first to de-oil it. Even assuming I can find a ready supply of acetone in reasonable quantities (it ain't cheap), would an alternative like white spirit, turpentine or meths do as well?
If I use an epoxy (like West Systems) is it still necessary to wipe with a de-oiler first?
Does Idigbo suffer from the same problem?
