Mcluma
Jacob":3i4jp6va said:It's not the router that's the issue - it's the bad detailing. You can do proper detailing with a router too and it's not going to take much longer, if anything.
If it's about economy then I'd highly recommend butt joints and skew nails.
If its a box rebate, to just take the glass, and you chissel out the corners, i cannot see what is wrong about that, it is probably better then first the M&T, rebate, then fit, as there is no room for error
if you do the rebate first, you still have to use a chissel to make it square, so where is the difference - Please explain
