bugbear
CStanford":1zd6egwo said:bugbear":1zd6egwo said:CStanford":1zd6egwo said:Percy Wells and John Hooper in Modern Cabinet Work describe the handiness of having a 'Bismarck' roughing plane in one's kit which by description is clearly a horned scrub plane; there is a line drawing too I believe. If precedence is needed in the British tradition, then, there you have it.
Or it might just be a jack; this Melhuish catalogue caused me to take pause and consider:
post725105.html?hilit=scrub%20textual#p725105
BugBear
The line drawing on the plate on page 8 of the Wells book shows essentially the old Ulmia scrub plane. The horn is the typical one found on ECE and Ulmia planes and not the turned handle of the illustration in Melhuish. They were referring to a German plane.
FWIW, there is a line drawing of a typical English jack plane found on the same plate.
Yes, that's all quite well understood. But the usage in the Melhuish catalogue is quite unexpected.
BugBear
