blurk99
maybe this ought to be in another section??
Which is stronger - a 6inch x 3inch 'joist' or a lamination made from three 6inch x 1inch planks???
my problem (1 of them...) is my garage roof is sagging - the internal measurements are 3.7mtr wide, 5.5mtr long, the roof is 'supported' by three 6mtr long, 38mm wide joists - one at the ridge and one each half way down the sides
my plan is to use 2 or 3 'joists' across the garage (resting on 'fenceposts' cut to length) with a central support that will push the ridge back up to it's correct height
i've also noticed that the sides are bowing out - the 3.7mtr width is at the end walls and in the middle of the wall they are 10cm further apart, so i'm planning on pulling them in with a ratchet strap before bolting through into the new supports for the roof frames, the new supports will be held the correct width apart by the frames
can anyone tell me whether what i'm planning is stupid / dangerous / easily achieved by a different method? would a steel support make more sense? any ideas about the weight of the roof itself? i'd reckon on 25sq mtr of 12mm T+G covered with pretty simple membrane then marley roofing felt 'tiles' - about 200kg all in???
cheers ladies and gents - all suggestions and ideas gratefully received (there's one caveat, can only get access to the edges - an old BMW that refuses to move is stuck in the garage, that's going to take about 2 years to get her up and running, i'd like to get this sorted this side of heavy snowfall if it arrives this year!)
cheers
jim
cheers
jim
