EdK
Started making a garden gate from scrap oak:
The top is through tenon/morticed.
Made the mortice with a Domino XL with the 14mm bit and then squared up the ends - also I increased the width to about 16mm.
Hand cut the two tenons in the top rail
Messed up the planing of one of the stiles (after work job...) so instead of planning is square I took a bit off one of the shoulders of the rail tenon... probably a silly idea but didn't want to run the P/T on a sunday (neighbours).
Planning on fitting one or possibly two more rails on the reverse once the boards are in.
Going to house the boards in a groove in the top rail and in a groove in the stiles.
As you can see the 'boards' will be made of more scrap oak!
None of it is wide.... ranges from 95mm to 45mm with most being in the 45mm range.
Boards range from 20mm to 35mm in thickness.
Questions:
1 - what is a good thickness of board ? 20mm?
2 - what is a good groove depth for the boards? 10mm depth?
3 - what is a good offset from the face before you make the groove?
I have 48mm width, so could go 5mm(edge) + 20mm(board) + 23mm(rails) = 48mm
4 - should I
A: just plane all boards down to 20mm thick and just square them up to have random width boarding without any T&G (5mm gap between square boards)
B : plane boards to 20mm thick then join them to try and get maybe 75mm boards, then T&G them all....
Thanks for any input!
Ed
Questions:
4 - should I
Ed
