RogerP
... I and many others of a similar advanced years weren't taught metric at school.Rich.ca":25em8smk said:.....why don't we just use centemetres and metres like we were taught in school?
beech1948":urj83dm2 said:Rich,
Its like this. NASA recently blew millions of dollars and 4 yrs of effort when the measurements on thier drawings did not agree...part were imperial and part were metric.......whoops. Nothing would fit together.
millimeters and meters work very well. Its either 347mm if short of a meter or say 1.347m if longer than a meter. Same applies to meter to kilometer. Upto 999 m its meters and over 1000m its kilometers.
The centimeter has no place in this at all. Frequently people write down a cm measurement and others come look at it and assume its mm....nothing fits. Centimeters are a waste of time and space. After all up to a meter its easy to just say 522mm. Its actually mentally more difficult to say 52.2cm and have to convert that back to use a ruler.
Say no to centimeters
30cm is a metric nearly one imperial foot. Timber is sold in feet.MCB":36t8u75l said:Can anybody explain why wood is sold by 30cm lengths rather than by the metre, please?
I needed some 2m lengths during the summer but had to buy 2.1m lengths
I could only just fit it in my car!
MC
phil.p":255td7ge said:IT's not. Try buying 2.2 metres or 3.7 metres.
MCB":1zl59nwz said:phil.p":1zl59nwz said:IT's not. Try buying 2.2 metres or 3.7 metres.
That would NOT have been possible, unfortunately, at the builders merchant where I bought it.
And it's rather too far to drive to Cornwall to buy from yours.
MC
woodenstuart":gl6ii8rp said:MCB":gl6ii8rp said:phil.p":gl6ii8rp said:IT's not. Try buying 2.2 metres or 3.7 metres.
MC
A10 timber will sell you what you want, as in they will cut it down from the 4.8M lengths they usually have, to your requirements.
It wasn't "designed" it evolved out of the needs of people working away at real things. Rods/poles/perches etc for ploughman farmers, miles/furlongs for travellers, acres for land surveyors, feet/inches/yards for builders and makers, pounds/ounces for grocers, 360º for navigators or astronomers, and so on and on.....Sporky McGuffin":2uwx8kja said:The Imperial system was designed to be as complex as possible, with differing multiples of inches in feet, feet in yards, yards in rods, chains, furlongs and miles, ounces in pounds, pounds in stone, stone in hundredweight, gross, tons, blah blah blah. It gets even worse when the Americans use the same words as us but for different quantities...
One might suspect that, like formal grammar, the primary intention of the Imperial system was to create a barrier to entry, in this case to the professions and trades.
Metric is simple and consistent and the units interrelate neatly.
Sporky McGuffin":2gdb0xxc said:The Imperial system was designed to be as complex as possible, with differing multiples of inches in feet, feet in yards, yards in rods, chains, furlongs and miles, ounces in pounds, pounds in stone, stone in hundredweight, gross, tons, blah blah blah. It gets even worse when the Americans use the same words as us but for different quantities...
MCB":19b4rqf7 said:Sporky McGuffin":19b4rqf7 said:The Imperial system was designed to be as complex as possible, with differing multiples of inches in feet, feet in yards, yards in rods, chains, furlongs and miles, ounces in pounds, pounds in stone, stone in hundredweight, gross, tons, blah blah blah. It gets even worse when the Americans use the same words as us but for different quantities...
The units in the Imperial system interrelate too
For example one gallon of pure water at 4 degrees centigrade has a mass of ten pounds
What could be simpler than that?
