Johnboy
Kity 619. Modified top to take Osborne mitre fence (like Norm's)
paisawood":39b76ltp said:Not sure that I should admit it, but I have a Felder KF700P.
devonwoody":1q3oggli said:I have the triton 2000 workcentre.
My gear is now nearly 2 years old and using the same blade.
I assume you use their bevel guide for the bevels - how well do you find it works? I'm loathe to spend the ~£60 if it's no good. :wink:devonwoody":1q3oggli said:I cut bevels.
I have the small sliding extension table, which copes with smaller sheets, but don't find it particluarly accurate - maybe I'm not being sufficiently careful when I set it up - any suggestions DW?.devonwoody":1q3oggli said:I cut large panels 8x4 if I put up the sliding extension table.
devonwoody":3gnpz5fn said:Hi Pete?
I expect yopu know that you can reverse the fence supplied with your Triton 2000 and you have an automatic 45 deg. bevel. The guides at the bottom can be set by adjusting the screws set into the fence. If you find the bevel cuts satisfactory using this fence you can step up to the adjustable bevel fence it works on the same principle.
The angles are accurate but you do have to calculate where the cut starts, no doubt this is the same if using other table saws. I have usually run a test piece to check if cuts meet my requirements.
With regard to the planer attachment its ok for cleaning up timber after rippingetc. but most probably never designed to cope with wide boards etc.
Jig saw works, but I have a band saw so my jig saw gear is redundant.
Newbie_Neil":rq2fk82s said:Is it as good as everyone says?
How do you fond your scheppach 2500
