gcusick":1pift5k1 said:
Except, of course, when you're fitting a metal or plastic part that needs an exact fit.
Yup, absolutely.
We live in a world of factory-made components. These often require tight tolerances - as you pointed out at the top, hinges are one such. Of course you can put them in/on the door with oversize holes, but many designs require "exactness".
I have seen older ones that need a 35mm hole for the door side of the hinge, but are held in position by small countersunk chipboard screws driven down the side of said hole between the hinge and the chipboard - nasty but effective.
And our existing kitchen, old and pretty nasty too, has the cabinet side of the hinges secured merely by plastic bungs pressed into 3/8"* holes. It was bespoke, so it's hard to imagine the maker didn't have options. To my surprise, where other parts have failed down the years, these have held up so far (23 years and counting for our ownership, but probably at least 10 years old before that). Some have had to be "settled" by percussion maintenance, but are still going. They wouldn't be, however, if the fitting holes weren't pretty tight tolerances.
Then there are things like dominoes, biscuits, various Lamello joiners, etc. all of which really need the tight tolerances they have.
If I make something with trad joints, I can adjust if necessary to get a nice fit and finish, but I live in a world where I mostly work on factory made stuff that needs repair or modification.
Don't get me started on Ik<cough>...
E.
*might be metric but I doubt it.
