Clearly nothing wrong with the one you were using!swagman":as6rjxmc said:Ed; these files are current production.
FWIW I've found in practice that ferrules aren't necessary on permanent file handles where the tang is seated firmly. If you need a handle to be used for multiple files though then a ferrule or wrap I imagine becomes a must, lots of splitting force applied to the end of the handle each time a file is banged home.swagman":as6rjxmc said:No on the file handles. I need to order in some brass stock for the ferules.
Rorschach":1s9kokgk said:I can't find Nicholson aluminium files in the UK at all or at crazy import prices
Have you tried curved-tooth (dreadnought/vixen) or millenicut files for whatever it is you're doing?Rorschach":3nf707nm said:I can't find Nicholson aluminium files in the UK at all or at crazy import prices
custard":1dtfgta0 said:Rorschach":1dtfgta0 said:I can't find Nicholson aluminium files in the UK at all or at crazy import prices
I'm not sure if it's Nicholson or not, but I bought one from a UK supplier. As far as I can recall it was just a standard stock item at any engineer's supply company. I wanted to tinker with the aluminium body of an Eclipse Honing jig, regular files just clogged up, the one I got wasn't expensive and it worked fine. Great for reshaping brass furniture hardware too.
ED65":3crwobbz said:Have you tried curved-tooth (dreadnought/vixen) or millenicut files for whatever it is you're doing?Rorschach":3crwobbz said:I can't find Nicholson aluminium files in the UK at all or at crazy import prices
Some related discussion here on BladeForums.
