Folding sawhorse idea
throbscottle
12 Jun 2022
Nuneaton
I could do with a sawhorse or 2 but haven't got room to store it/them. So I was thinking, make each side with a board connecting the legs, to maybe 1/3rd of the way down, and hinge one side, so it can fold flat, and have some kind of flappy arrangement between the bottom edges of the 2 boards to prevent minge movement when it's in use.
Does the idea hold water? Anyone?
Oh yeah. Tee hee hee.
I never even thought to look for existing designs. I looked at a couple of slot-together ones here on UKW (very impressive) whilst looking for how to make a normal one, then went straight to "folding" in my head.
Right here's a rough drawing I did in LibreOffice Draw. It's just a way to make one side fold in and be able to lock it when in use.
    29.3 KB
If you've never used one, the commercial versions are good. Expensive obviously, but metal joints make for speed, strength and stuff like adjustable legs.
I can vouch for toughbuilt, bora have similar, and I have a related product that tells me the dewalt yellow and aluminium trestles derived from their mitre saw stand will be strong and sturdy too.
Bought ones may be nice but... Budget. And the Screwfix ones do look spindly. I'd probably get annoyed with them. Anyway I have a load of reclaimed wood taking up space so I may as well use some of it.
I like the ones in the video - way better than my idea and the legs slope in both directions, unlike many out there. I really want a top wide enough to balance a cup on though. (Cough) I mean, to clamp something to. Yes, ahem... Experience being that I can do a remarkable lot balanced on the edge of an old pallet (which also works as a very low level sawing platform when laid the normal way round) so there's a definite advantage in having a portable narrow work area, but without the proclivity for falling over :)
I have a small workshop and use whatever is to hand (often a piece of flooring-grade chipboard) on top of two plastic trestles similar to these…
https://www.screwfix.com/p/forge-steel-saw-horses-415mm-2-pack/964jc?
to cut up bigger stuff outside.
They are very light, fold up flat and surprisingly stable although just a little too narrow to balance a coffee cup on 😅
Maybe you could make something similar with a slightly wider top?
I have all sorts of saw horses, wooden, plastic and metal ones, but I find them awkward for when I'm trying to hold and cut pieces of timber, so my solution has been to use a folding hop up with a piece of a fire door blank screwed on, works really well and It can still be used a a hop up, and folded away.
Good idea - I have a very distant memory of those from somewhere but had completely forgotten. Might get a set - thanks! Plank nailed onto the top would also make a clamping space.
I'm feeling so stupid for never thinking of this, it's pure genius.
My hop up will be getting a wooden top fitted this weekend.
Thank you 👍
Got a pair of these Metabo ones for 99 quid.
https://dvspowertools.co.uk/shop/po...-work-trestle-set-twin-pack-mab-82-626990000/
Absolutely can`t be beaten for value, cheaper and better than the Toughbuilt or Bora ones. Even making your own you would struggle to beat the price.
Has holes for clamps on top, adjustable side arms for different thickness timbers when making a table, adjustable height, leg stops on one side for holding stuff vertically or cutting pipes etc, very strong when set up. Only complaint is they could be a bit taller.
I also employ the hop up technique as mentioned above, as well as the top of the vacuum technique and the couple of toolboxes technique..
it's pure genius
Not sure about that @Doug71 just what we practical peeps have to do.
I'm actually a bit miffed, I made one years ago using a taller hop up and a home made MFT type top out of some Tricoya I had left over, It was left out in all weather and worked a dream with all the holes, until it went walkies off a site I was on.
Excellent idea , my hop on will also be getting a wooden top , maybe offcut of kitchen worktop.
How did you fix it to the hop on , you mention bolting on does that mean you drilled holes in you hop on or did you clamp the wood on some how?
