bugbear
Jacob":22nx6ld4 said:So we've laid to rest the flattening myth pretty convincingly.
We've shown that flat chisels are needed for accurate straight cuts.
BugBear
Jacob said:So we've laid to rest the flattening myth pretty convincingly. This should save woodworkers millions of hours! Should there be an official announcement of some sort?
quote]
It would save woodworkers millions of hours too, if they all stopped typing hundreds of posts about flattening chisel backs and just got on with it. :shock: (hammer)
marcus":4znri9eo said:..I can't work out if he is trolling for fun or actually means what he says...
marcus":pxo3mudy said:Obviously it's a waste of time and energy.
bugbear":3slfuvre said:We've shown that flat chisels are needed for accurate straight cuts.
BugBear
more emphasis needs to be placed upon tooling practices than the tools themselves.
GazPal":3oneq8dt said:bugbear":3oneq8dt said:We've shown that flat chisels are needed for accurate straight cuts.
BugBear
How on earth they managed to build the Egyptian pyramids, Mayan temples, Parthenon and Harrison's wooden timepieces without perfectly flat chisels I'll never know. :roll:
Chisels have limitations when put to use and this gave rise to the development of the hand plane, abrasive papers, etc., etc.. Whilst the reach of a paring chisel is handy, the tool itself is not necessarily an accurate tool, as it's blade - by nature - is flexible and can distort during use. Especially so when it encounters grain travelling in contrary directions. This makes it necessary for one to constantly relax/increase downward pressure on the blade with one hand whilst the other steers via the handle. We don't introduce it's edge to the material and trust it will travel straight and true when driven forward primarily because it won't. Again, more emphasis needs to be placed upon tooling technique, because finite degrees of accuracy within a tool's manufacture are not the sole factors dictating accuracy in the cut. Shift focus on to chisels driven via maul or mallet and the pursuit of a perfectly straight blade becomes pointless as the steel shifts beneath each strike and wanders freely in the cut unless guided by hand and eye. Our senses play a much greater part in the ability to cut straight and true than seems accepted.
Books don't tend to teach this and a scientific approach toward chisel use tends to prove inappropriate unless every eventuality can be calculated with provision for formulae and converted to describe the physical reactions of materials, tools and tool user. But then we'd need to shift a proportion of focus away from crafting and on to calculus and translating scientific results into actions belonging in the realms of the machine driven world.
How long is a piece of string/How accurately ground should a blade be along it's length? It depends...... I mention this is because much depends upon cut dimension (Reach & breadth), blade flex and potential user error. Accurate tools are a real and genuine necessity, but - even with laser-like precision - more emphasis needs to be placed upon tooling practices than the tools themselves. Otherwise we become tool owners and not tool users and run the risk of losing sight of the skill sets developed over the ages for manipulating timber into various forms.
I tend to err on the side of accurate layout, sound technique and matching a tool to it's given task as being necessary for one to achieve accurate work. Straight or curved. Pinpoint accuracy in woodworking is perfectly possible without any need for engineering tolerances in the tools we use and this fact has been proven/borne out time and time again for millennia.
Of course I mean what I say. Do you think I am furtively flattening my chisels in secret?bugbear":17r147rz said:marcus":17r147rz said:..I can't work out if he is trolling for fun or actually means what he says...
I've never been able to answer that one either. I think it's quite a lot of both.
BugBear
Conversely, a curved or back bevelled chisel will require a great deal more input and control from the operator for the same operation.
phil.p":2w76c7le said:Right, that's that out of the way, then. I assume we should all flatten the soles of our planes? No!..........no!............don't go there!
Peter Sefton":3687kiru said:We do have 80 micron (180 grit) lapping films - 100 is pretty coarse for such high quality chisels, the finer the abrasive the flatter it will be and the more imperfections it will highlight on tools.
I have never lapped Blue Spruce but would be reluctant to do so on very coarse abrasives as I would hope the chisels are made to finer tolerances than that. Lapping on glass plate does show up all manufacturing imperfections which you may not show up with other sharpening mediums.
phil.p":2hcprq6n said:Yes, I meant flat not "co-planar".
marcus":2hcprq6n said:Conversely, a curved or back bevelled chisel will require a great deal more input and control from the operator for the same operation.
This has been my experience with tasks like trimming tenon cheeks. It's easier, quicker and pleasanter if the chisel is flat. I'm not talking engineering flat. But the point is if you like to keep your chisel backs flat for this reason, and you like the additional sharpness that a polished back brings, then the back needs to be flat enough so that when you rub it flat on the stone the mm or so behind the cutting edge is polished. Which sometimes takes a bit of work when the chisel is new, but in my experience repays you with increased efficiency and enjoyment thereafter. Which is why most of us who do it, do it.
And no I am not advocating engineering tolerances for chisels — just the work necessary to get the result indicated above.
