Jacob":2d5kv555 said:
It's odd that the normal more or less universal way of sharpening only 60 years ago … is now seen as weird, verging on perversion!
"Perversion" is probably too strong; I'd call it a historical aberration, or degenerate technique.
It gets at an issue that is wider than just sharpening stones. Guys like you and Sellers talk about the techniques you learned in the 1950s as though they were some sort of "normal, universal" way of working. It's as if the fifties were the Golden Age of hand tools, when in reality they were more like the Dark Ages. Hand tool skills started declining in the mid-19th c. and probably bottomed out in the late 20th c.; By 1950 they were basically circling the drain.
If we look at the techniques that were commonly taught and practiced in the mid-20th c., we'd see that most (not all) woodworkers:
- rarely flattened stones and often used badly hollowed ones.
- routinely rounded or dubbed the backs of tools.
- used convex bevels or eclipse-style guides.
- had no idea how chipbreakers worked.
- used shoulder or router planes to pare tenons (after deliberately sawing them fat).
- chopped mortises undersize and then pared them to size.
I could go on, but hopefully everyone gets the point.
On the other hand, if we have even a tiny bit of intellectual curiosity and we try to figure out what woodworkers (again most, not claiming all) did in the 18th/19th centuries, we see that they:
- both flattened stones when necessary and (as Jacob rightly stresses) made an effort to keep them flat in use.
- avoided rounding or dubbing of backs.
- used a primary bevel/ secondary bevel freehand sharpening technique, and considered convex bevels to be bad form.
- sawed tenons to size and if necessary pared them with a broad chisel.
- chopped mortises right to size, without drilling, paring, or other complications.
In every case, the earlier technique is faster or more accurate or produces a better surface. Now, it's no skin off my nose if you want to use any or all of the less effective methods; why would I care? What bugs me, and the reason I posted in the first place, is that you constantly misrepresent these methods as "normal," "universal," "what everyone did," etc. And no doubt you'll keep repeating these claims forever, but people should know that they're not true. That's all.
