pren
Hi all.
I've just been to look at a job in a really old cottage. The walls are made of stone (ie: boulders mortared in place - not sure what the actual term is ) and are covered in about an inch of plaster. The walls are pretty far out of plumb.
What's the best way to fix kitchen wall units to these walls? The client has said that the plaster/render is very sound and they've hung things from it before.
I was thinking of grip-filling and screwing batons to the wall at the top and hang the units from these so the top is plumb with the bottom, if that makes any sense?
Plan B invloved using grip-fill/sticks like sh*t and screws to fix a peice of 18mm ply the same size as the wall units to the wall. Shims/batons can be fixed to this to bring the units in line. My thinking being that this would spread the load over a greater area than just at the baton.
Any thoughts? :-k
Any thoughts? :-k
