I need to fix a flange to a paving slab. The flange is about 10mm thick with 2 large holes (17mm?) predrilled, the slab is only about 20mm thick. what is the best way of doing it?
I cannot use through fixings because the slab has no clearance underneath. It is being used as a parasol stand/guide through the centre of a table. Into the flange is a piece of tube which is fixed at the other end into a flange secured to the underside of the top. The base itself is a Gabon basket filled with stone, which sits on the slab. I haven't filled this yet, but I would think that there will be 50-75kg of stone in there, based on 2-3 DIY size bags.
I haven't used many anchor bolts, but they always seem much longer than this.
