AES
As already said, I'm definitely NO expert in "decorative" finishes for ali. But I must say that all the items above look "brilliant" (sorry!) to me.
The only things I can say about ali tarnishing and or corroding is:
1. It does depend an awful lot on the atmosphere - any dampness (and especially a salty atmosphere) will accelerate the process);
2. A lot depends on the actual alloy (which of course, in the home workshop is something we usually have no idea about);
3. To reduce corrosion and tarnishing (not prevent, you can't) in such as aircraft structures there is an etch primer process followed by "undercoat" then colour paint - often 2-part PU. Or if internal, in maintenance areas, etc, a very hard-wearing matt "paint".
Even then, if you look at the floor beams around the toilet area for example (not trying to upset anyone here, sorry in advance) when an aircraft comes in for major overhaul you will ALWAYS find some corrosion. Often to the extent that parts of the floor beams have to be replaced for new in sections (and all "iaw the book" of course). This despite the manufacturer going to great lengths to ensure the floor beams themselves are well protected as above during build, AND despite the galley people going to great lengths to seal the "rubber" matting between the loo and the structure. I guess that's because urine is acidic (or is it alkaline? Dunno). Such major overhauls would typically take place every 6 years or so BTW.
Therefore my GUESS is that what you blokes are doing with your micro crystalline wax (what's that BTW? Excuse my ignorance) is forming a pretty effective seal between the ambient atmosphere and the surface of the ali. Whatever, from the above pix it seems to work well.
And I thought the example of the razor (above) VERY interesting. How long was it in and out of the water when you were wet shaving, and what steps, if any, did you take to dry if off before next use please?
And BTW, I also have a small router plate made out of ali ("found" in a scrap box when I was working). That, just like the example above, shows no blemishes at all. I therefore assume it's a matter of what the alloy actually is (I have no idea).
Interesting thread this.
Edit for a P.S. I too would be interested to know what your crystalline wax consists of. TIA
