If you are going to be doing glue ups on it some finish might help. Water based poly varnish should do it. You will probably want to do both sides of the top to reduce warping, which means you might have to be disassembling a bitPaxWorks":3ekwpsi6 said:I finally had a full afternoon to dedicate to the workbench today, and I'm happy to say it's all done minus a few finishing touches:
It's far from perfect, but for a first project I'm more than happy with it. Definitely learnt a lot and really enjoyed the process.
Now I just need to soften up some of the edges on the plywood. I wasn't sure whether it was worth putting any kind of finish on it, so any advice on that front would be greatly appreciated
Thanks for all the help and advice, now I just need to figure out what the next project is going to be!
Spearmint Wino":2bbnpxm8 said:Looks good! I’m hoping to build something similar next year.
Now it’s finished does it have the heft you were after? Would it be a suitable bench for attaching a vice to?
will1983":1fjqk3a2 said:Spearmint Wino, this is predominantly a power tool and assembly bench. You could fit a vice to it but it's not really suited to heavyweight hand tool work like mortising and hand planing. If you need a bench for that your better off building a Paul Sellers type bench.
