Well, this is terrifying.
The central reasons for my posting this is for my own self-creative confidence and to make some small contribution to the newbie community. I also wanted to see if I could do it without self-deprecation or warnings to how crude it is (guess I’ve just done it).
Anyway, my partner is what they describe as ‘horsey’ and she needed/wanted a bigger sturdy step with which to mount the oversized pet.
Though I am indeed a wood newbie I’m Not new to ‘hand skills’ I suppose. I’m an Armourer (fixes firearms). Due to the background in engineering, I became so incredibly frustrated that I could not get this simple project, with what I considered an easy material to work with, straight, flat, square and parallel. I will say that all this wood was from old large pine boards lying around a friends farm. All bowed, all twisted. And I went out and bought a No. 4 Record, some
Stanley chisels and a cheap hand saw. How hard could it be?
I planned to knock out some mortices like Paul Sellers and bobs your uncle I’m
In the club. Although I made a reasonable practice joint, when it came to the mounting block the wood was I think was rotten, as the walls of the mortice were sort or loose and soft. So I ended up making 12mm dowels to join the sideboards together, the frame, and the steps. I thought trough dowels would look
Like nice on the steps but, well you can see. I stained the steps which again was harder than I thought it would be, and finished it all in a few coats of danish.
Though using a plane for the first time was utter **** I feel I’ve learned enough to at least take material from where I want it and flatten a board. But I’ll be honest, I don’t want to spend days, literally, doing that at the start of the every project. So I’m picking up a Record Power BS300 (found here from Aramco) and a
Elektra Beckum hc260 later this week.
The mitre saw I bought at the end of the project but was more trouble than it was worth. Evolution Rage something or other. Took a day to get it square, it’s actually set up off square and whatever play is the slide and positive stops pulls it square. Witchcraft.
Thanks for reading and my hat is firmly off to those of you who work with this ‘easy’ material.
Bonus, a nearly finished chopping board
