AES
Note please, I'm NO expert, and only use my little nailer/stapler very seldom, but it's "Alidli" (can't remember which) and it's fine.
To run it I have a cheapo supermarket compressor, with tank (can't remember how big, & it's out in the garage). The only problem with it is that it's VERY loud - too loud to run in my cellar shop. But in terms of "maintenance", so far (roughly 10 years) none required apart from draining down the tank after every session. This drain valve is a small knurled brass plug under the tank - you just reach underneath, open a couple of turns, wait until all the hissing stops, then close it. That's it.
Perhaps I should add that I use it for spray painting sometimes too, so I added an after market gauge/reducer/water filter. But so far no sign of rust at all (should be inside if at all - if it's outside it's a bit too late!) but last time I shone a bright light up there (plug fully removed) no sign of any rust.
Any help at all?
Any help at all?
