1/13" Scale 13th-15th TARDIS
Some more progress with the TARDIS model kit. I've glued most of the pieces, so far I've gotten the roof & base, the three box panels and the two doors. Which brings me to my next point; the doors will be functional with proper hinges (hopefully, if everything goes to plan!) it's possible with the kits at this scale. I have encountered a slight issue though, the hinges which I've got are a bit too big and don't fit so I'm going to look for some even smaller hinges tomorrow and hoping they fit, if not...I may have to scrap the opening doors feature. 'Hopefully the latter doesn't happen...I am a bit worried though 😟
It looks like you have pegs top & bottom on the single doors they would be your hinges would they not?
Edit: that to they
Always shown with the rh door opening inwards, if I was designing the actual Police box I would have had it opening outwards,
1, it would be more secure and 2 it gives more room inside, obviously in a real life Tardis that wouldn’t matter lol.
Edit: that to they
You are right @Phill05 , they do have pegs at the top and bottom and they are meant to be the hinges for the doors. I was going to mention this in my initial post but I had to run a few errands and wasn't able to type up everything in one post so, my bad on that.
But, yes the pegs/tabs at the top and bottom are the hinges for the doors. The only problem is, because the pieces from the model kit are very thin (in terms of the thickness of the piece), I'm quite worried that those hinges will snap. There's also rectangular rod piece, which can be placed at the back of the door, to add support to the doors when opening them. But again those rod pieces are quite bendy and fragile, after I took off the packaged masking tape. I'll send a diagram-ish picture to hopefully show what I mean:
I hope this helps...sorry if the image isn't clear!
I believe, and I could be wrong on this, Police Boxes in real life did have doors opening outwards so you're not wrong. In the show however, the doors have always opened inwards and I'm highly speculating that this kit is designed to have the doors opened inwards as well so I don't think the doors can open outwards...
I see what you mean, what if you replace the rectangular rod for say 1mm brass round wire that would give the strength needed and would make it easy to use the door.
That's not a bad idea actually, I've just purchased some 0.9 mm silver wire at a small DIY Plumbing shop , it's not brass but it is sturdy and can be straigtened into shape. I'll have to look into this for the next couple of days and I'll let you know how it turns out 🙂
Hey folks, so I'll need some more time to look at the doors and find a solution for them. However in the meantime, I've decided to paint the roof & base and the three wall panels. I've added two coats of paint, I'll send a picture of how it looks tomorrow. My plan is to add a couple of washes of some lighter blue to give it that multiple shaded look that the 13th-15th prop(s) had. Reference image here:
Then once the entire painting stage is finished, I'll give it a coat of semi-gloss lacquer to seal the paint and give it that slight shiny coating that can be seen at certain environments.
Here's the base colour applied on the fully assembled pieces. I think two coats has done it! 😄There's some splodges of extra paint here and there, I've done my best to evenly spread the paint. Go easy on me, it's my first time doing this... 😅😟
