Andy Homan,
Try your 6 tpi rip--why not? I probably should repeat that Mike's first recommendation was frame saw, a less expensive item, and indeed back when folks resawed veneer for a living, that's what they used. The narrower blade overcomes the binding and steering problem, and because the blade is in tension, it can be thinner and cut a thinner kerf (= less work). I just feel more comfortable with a plate saw, and am not doing this for a living, so don't have to be efficient. But try the saw you have--the key to it is either to get a starting kerf as Andy/London did, or else saw in from the corners with the saw tracking down two gauge lines at once. If you start right, the set of the teeth will probably give you enough room to manuever and stay on track. It's mainly a matter of sweat.
Andy from London,
I'll get photos. Your chisel cabinet is a great design, since when it is closed the chisels can't go anywhere, but then they are offered forward when in use. The resawn panels also add a lot to the aesthetics, with the bookmatched fleck in the oak. The strap handles are grand too. Really a fine design and fine work.
Wiley
