Well, I like to please my audience, so today's Wizer Whisperer is about fitting the aftermarket fence.
I got this idea from someone else who'd done it some time last year and promptly forgot who it was. I'm sure they did a video of it. Another member, Green, reminded me when he mentioned he'd also done it. It's the
Axminster Rip Fence Upgrade, which is intended for use on bandsaws. Green very kindly sent me pics of how he mounted it. Which is very straight forward. Here's how it goes.
Unpack the box, throw away manual...
...(make manly grunt)
Lock the fence onto the rail and then clamp it in position over the table. I have positioned the new rail so that the fence will lock just a fraction past the left hand side of the blade, thus giving the maximum capacity to the right.
With this clamped in place, I could mark the positions on the old rail for the brackets to be mounted to. Note: Green used a piece of 4mm angle Ali around the old fence rail to bulk it up. I didn't do that because I'm a cheap bone idle so and so. With the bracket positions marked, I drilled a 5mm hole for each.
and then used an M6 tap in the drill press. Actually, I did consider using the drill press to tap it, but realised this was foolish. What I actually did was use the tap chucked in the press but with hand pressure to twist the head. But I still managed and oopsy...
.. by putting too much pressure on the drill press handle, I manage to strip the thread :roll: No bother, these brackets are fully adjustable to anywhere along the old fence rail, so I just moved it along a bit and did it again.
The screw tightened up nicely and I'm sure will be strong enough. Although if I ever feel the angle ali is needed then it's an easy job to add it later.
That's the bulk of the work done. I did manage to get it fractionally too high and as a consequence there is about a 2mm gap at the beginning of the fence.
I'm not sure is this really matters. The fence does not glide along the table like I'd hoped, but is a massive improvement on the old one. The problem I have is comparing everything to the supersaw. That fence would glide effortlessly over the table. But then that had a pad at the end of the fence (and was nearly three times the price). I'm wondering if I should fit something like a foam pad at the far end of this one to both take up the 2mm error and help with movement.
If anyone is considering doing this then there is one massive (well bigish) consideration you have to make. You loose quite a bit of rip capacity.
The new fence gives me 540mm from blade to fence. However, the way that this is installed, you can continue to use the old fence if needed. So if you need to rip more than 560mm, you just get the old fence out. Personally I don't think it's going to be too much of a problem. Considering my health, I'm probably going to have to restrict my woodworking to small items anyway.
One thought I had was the rail that comes in this kit could probably be made in wood. The profile is pretty simple
The fence runs on bearings, so you'd just need to use a wood that was unlikely to move a lot. Something naturally greasy might be an advantage? Another reason for doing this upgrade is the ease of adjustment.
I'll cover that when I come to do it. I want to get the dust extraction sorted before I start setting it up and using it.
So there it is. No major cockups today. Well none that I've noticed
