wizer
- Joined
- 3 Mar 2005
- Messages
- 15,589
- Reaction score
- 1
'here we go then.
Today I needed to cut the cover panels for the side, base and back of the saw. The base will eventually become part of the hopper. But until I work out how to do it, it's just a piece of 18mm ply. The side replaces the fabricated one that came with the saw. By cutting off the corner of the motor assembly, I can now fit a flat 12mm ply panel. Similarly, with the blade cowl in the trash can, the large hole in the back that allowed the dust port to move, can now be covered with a piece of 12mm ply.
To cut these panels I needed the saw setup. I put the rails back on and checked the blade for square. Normally, I use the wixey angle gauge, which I can get to 90.1:
That's fine by me, but I thought I'd check it with an engineer's square (yes, I know the square is battered)
While I was here, I thought if it could get to 45 ok.
It's hard to see in the pic, but the wixey shows 45, but the engineers mitre seems to be touching at the top and bottom, but not in the middle. I'll do more extensive tests on that later when I properly commission the saw.
Next was to true up the fence itself.
Using the same jig in the same slot, I took a reading off the front
and the back
So the fence is 20 divisions or 0.2mm away from the back of the blade.
Before I made any adjustments I checked if the fence was square to the table
It's hard to see in the pic, but there was about a 1-2mm gap (must get some feeler gauges) at the bottom of the fence, meaning it was leaning in.
So I looked in the manual to see how the fence adjusted. Silly me, why would the manual have that sort of information?! :roll: :x All has is a picture of the adjusting screw at the back of the fence.
Again, hard to see, but it's a slotted screw on the back of the fence. One big problem with this... I can't move it! Now, I freely admit I'm a rather weedy geek, but I'm surprised that I can't turn it, even a bit. Being that the fence is just 0.2 away from the back of the blade, I decided this is absolutely fine and so left it. I did find it odd that there is only adjustment on one side, the screw on the other side is blanked off. Inside the bearings are the same. The side that is adjust able on the outside, had a slotted screw. The other is blank
There is no other form of adjustment on the underside. Unlike a Beismier style fence, where you have at least 6 points of adjustability.
I was on my own to work out how to adjust squareness to the table. But I guessed it would have something to do with the two screws in the top of the fence
But...
I couldn't shift these either :shock: . Must have spinich and shreddies for brekky tomorrow :roll:
I gave up pretty quickly. The panels did not require precision.
Lastly I needed to affix the tape measure. This was also doomed to fail. Why?
Because this fence was meant for a bandsaw, who's fence is generally on the other side. So it only went up to about 300mm on the right! I'll be tapping up Mr Maskery for a proper one :roll:
So I just got on with cutting the panels. I will come back to setting everything up later when I have finished everything else.
Cutting the ply panels was really enjoyable! I know that's probably an odd thing to say. But the way the saw was setup before I was always reluctant to use it. The only thing that's really different is the tiny adjustment on the blade alignment and the new fence. At the moment I'm using a tape measure to set the fence, but it's much easier to do with this fence. You can get it near, but a little pressure on the locking handle, then tap it to the right measurement. Let's just say that before was no where near that simple!
The back panel needed a notch cut out to allow the rear fixing for the motor assembly to pass through. Very quick and simple.
I couldn't fit them as I had no bolts of the right size and as I'm not driving yet, I'll have to wait for the wife to run me down to Toolstation in the morning.
I finished up by re-sawing a chunk of unknown reddy hardwood to use as ZCI plates.
Long post for not a lot of work, I know. But there you go.
Tomorrow I have hospital appointments all day. Thursday I'll be back at it. Fixing the panels and then fiddling with the design of the hopper. I may also have a go at the ZCI's if I get time.
I remembered today that it's my wedding anniversary in two weeks and I was supposed to be making my wife a jewellery box :shock: So I might have to delay making the rolling cabinet and at least have a go at the box.
and the back
But...
