Festool Vac (vice / clamping) system
Steve, given that you have seen the vac in action do you think it could effectively replace a traditional vice?
It would seem to be ideal to overcome other workholding problems eg bench top issues and the difficulties of holding thin items, which I seem to continually encounter.
I think if I had one I would fit it into my bench, if that makes sense. I notice that with all the attachments it will cost £1,000, which is too much.
On another note, what are the consequences of getting yourself stuck on it? If that is not a silly question. :? :shock:
Cheers, all. Tony.
:shock: :shock: Just make sure you have your mobile in your pocket, give one of us a ring and we'll come round and unstick you :lol: But we might take a photograph first........ :-k :lol:
Cheers :ho2
Paul
It's a tough call. For some kinds of work then yes, certainly. If you are spending all day finishing panels and tabletops, it's perfect, as you can get it into any position without having clamps and stuff getting in the way.
But there is a limit as to how small the workpiece can be. There are two sucker cups you can fit, one round for general work and one long narrow one for pieces such as table legs. But some workpieces would be hust too small and then I don't see any alternative to a trad vice. SImilarly I don't see how it can hold round stock.
You don't need to fix it to the bench, it does that by itself. Magic! :)
Paul
I'll provide the camera! :)
Interestingly Axminster have just started stocking this:
http://www.axminster.co.uk/product-Adam ... 785488.htm
isn't it just. But to make your own would make it big and heavy I guess?
The Ax device includes a venturi vac pump, (Built in? Separate?) so price is not quite so bad.
