I may be wrong but even though it says no return UK consumer law says that you can return it within a certain period. Iwould have thought if it hasn't been described correctly this would be the case anyway.I needed a spare lead for my Domino 500, the only corded Festool I own, and purchased one from eBay. However, it turns out that the original Plug-It connector and the one I received are not the same, and the newly acquired one does not fit my DF500.
Here's what my original connector (came with DF500) looks like,
and here's the one I purchased separately
- Its internal shape is different from mine
- it was a ebay "no return" purchase
View attachment 158088View attachment 158089
I have two questions:
1. How many different Plug-It connectors are there?
2. Has anyone been able to successfully convert one to another without risking damage to an expensive tool?
- I am only interested in making it compatible with DF500 without breaking DF500. No other (more power hungry) tools are planned.
Thank you
We are on the second page of this thread, I have not seen a single attempt at answering to my original questions and do not have much hope, but will try one more time anyway:
My original questions were:
- I am only interested in making the cable compatible with my DF500 without risking damage to the tool. No other (more power hungry) tools are planned.
I did a similar conversion on some of my tools using Hylec m/f plug-in connectors as close as poss to tool. I've not had any problem with 'snagging', with extractor hoses - yes! Not having a cable wrapped around it makes for much easier storage. I got my connectors from CPC, but now Screwfix sells them.I made a DIY version of this long before I ever became aware of Festool. I used Hirschmann plugs that are (much) slimmer than Festool plug-its and neutriks. I shortened the power cords of a few tools to just a few inches and fitted the inline plugs.
Eventually I got tired of even my super slim plugs hanging off the back of the tool and always catching on the edge of the bench or the sheet I was working on. I put long rubber flexes back into all the tools I'd adapted. It seems a good idea but it doesn't work in practice. Fitting an extra long, high quality rubber flex to a tool that doesn't have one on the other hand IS an upgrade and I've never reversed that mod.
It won’t fit a 110v machine because he is going to cut the other end off to fit a 13 amp plug Do be careful the poles end up the correct way round once the cable is modified as it will certainly not have a warrantyIf selling the 110v cable isn’t a viable option you have nothing to lose by trying to modify the plug on the end. If you succeed in making it fit into your 240v tool (shouldn’t be too difficult) it will still fit into a 110v, unless you infill one of the cut out sections. Not an issue if you have no 110v Festool.
It looks like it simply needs some of the moulded plastic trimmed off and, preferably one of the ‘V’ cut outs infilled by gluing something in.
There’s really no danger of damaging your tool unless you try forcing the plug before it’s properly trimmed to fit.
If modified to fit into the female/socket of the 240v tool it will still fit into the socket of a 110v tool and could, inadvertently, feed 240v. That’s why it would be advisable to fill in one of the cut out ‘V’ sections to ensure that won’t happen.It won’t fit a 110v machine because he is going to cut the other end off to fit a 13 amp plug Do be careful the poles end up the correct way round once the cable is modified as it will certainly not have a warranty
Have you actually stoped and thought about why they are different ! If you have ever worked with interconnects you would realise that a lot of effort goes into making sure that the right connector for an application will only fit the right mating half to prevent damage to equipment by the use of keying, which is why your plug and socket do not fit as it prevents someone putting 230 volts into a 110 volt tool.you have nothing to lose by trying to modify the plug on the end. If you succeed in making it fit into your 240v tool (shouldn’t be too difficult) it will still fit into a 110v,
It would, if I had thought about that at the right moment. Thank you for the suggestion.@fleyh Would it not have been far simpler to have just put a call out in the wanted section for a 240V lead in the first place.
I am not messing with anything. The point of my thread was to understand why there are different connectors with the same name (Plug-It), how many such types exist and if one is convertible to another.I find it hard to believe your messing with a purposefully designed safety feature,
If I was being pedantic, the shilling (before it was withdrawn) had a purchasing power of approximately £0.70 in today's currency. I bought my 110V cable for £15, which is around half its usual price of £30. So in a way, I was trying to save approximately 21 shillings.to save a shilling.
Thanks to @MikeK I now know that there are 3 types, 2 of which are 110V and only 1 is 240V, which means I can buy any 240V lead and it should fit.
I see. Thank you for the clarification. Looks like my only choice (if I was to buy another lead in the future) is to buy with "return allowed" option. Will keep that in mind.Just to be clear, since I like to choose my words carefully, these are the three I know of. There might be more, and if so, I have never seen them.
Which is exactly why I suggested that he should fill in the appropriate’V’ section that prevents this happening. Regardless of the fact that he doesn’t have any 110v Festool.Have you actually stoped and thought about why they are different ! If you have ever worked with interconnects you would realise that a lot of effort goes into making sure that the right connector for an application will only fit the right mating half to prevent damage to equipment by the use of keying, which is why your plug and socket do not fit as it prevents someone putting 230 volts into a 110 volt tool.
Or maybe to buy the correct on in the first place?Looks like my only choice (if I was to buy another lead in the future) is to buy with "return allowed" option.
