busy builder":3nipibow said:
May beyour boiler is m0re efficient than mine, but a combi will save you money straight away as you are only heating what you need. On top of that are the benefis of the condensing system.
My knowledge of Boiler technology and CH systems is at least 30 years out of date but can you even get any benefit from fitting a condensing boiler to an existing old style system, surely the water temp management / bypass controls will not be in place to match the boiler.
It's for sure fitting a combi boiler would entail a whole new rework of the hot water/CH system and loose any airing cupboard/drying room facility an older property is likely to currently use.
The old boiler casing fitted in my property is not the most efficient by modern standards and has had new pump/burner fitted by me over the years but every time I sit down and try to work out the efficiency advantages versus the installation cost of a new (oil) boiler I come out with a 10+ year claw-back. Of course I may just be wrong in my understanding of modern technology.
