It will stay on that table, which when my new hose arrives will move back over to the corner it was in when you came. I have to say, the SIP is perfect for what it is. Change over is quicker than my previous Axy model, no taking off tables, the finish seems very good, the axy planer had trouble with the european oak, could have been the blades were dull, but this one seemed to go fine. Thicknesser is good and its very quick to get the table up and down. As long as your not planning to work with really long boards its fine. I'll have to keep saving for the Jet310 so it will have to do for a good while.
It is heavy, and it is noisy, brush motor, as noisy as my big one was, not as quite as the induction motor in the CT150. The finish is spot on, always worth a clean to get those last machining marks thou.
Did I tell you Mick I got a LN 4 1/2 for my Bday? When we discussed the difference of weather it would be much, it is, totally difference experience, very heavy.
I'll get a few more pictures tomorrow, got a few drawers done on the outfeed table, got the Router hooked up to the NVR for the first time ever, the top is inlayed into the main top, fitted a set of Hafele adjustable feet for 99p of ebay so the table is level with the saw table now. Just need to fit a collection box underneath the router so I can glue the top down and trim the sides pieces.
