Erbauer 239 mitre saw
Bench dogs are normally 20mm metal dowels that are used on an MFT table. Do a search if you need more info. If you buy a toggle clamp you can make a 18mm dowel and ply plate to screw the clamp onto. The dowel then slots into the clamp hole on your saw and screwed tight with the thumb screw.
Hope that's useful.
Hope that's useful.
Ah i see now thanks
