"Emergency" weekend project build - EV charger plinth
Hypnotic Chimera
Directional Consultant Extraordinaire
UKW Supporter
27 Sep 2024
nr Lincoln
Sat 18 Jan 25
This has all happened way faster than I had planned or expected.
Having committed to changing my car for an EV - and having been given a decent trade-in value for my car - I stuck my car on FaceAche MarketScam for a bit more than trade-in value, but at way less than it's actually worth.
First guy to view and after me to taking him for a spirited drive he simply offered a small deposit and said he'd take the car. No negotiation. No offers. Just committed right there on the spot at my advertised price.
I had a charger install sparky over on Tuesday (14 Jan) to do a quote for installing charger. Not an easy one - since my car port is separated away from the house
My car was collected and driven away on Wed (15 Jan).
The charger is ordered and in transit - as is the integrated 6mm plus cat5e SWA cable (££££s).
Install is happening late next week. I should also get the car late next week.
I now have a bit of an emergency to rig up some kind of plinth that the charge point will be attached to.
Problem being that I don't have my car and can't go out to get "long" timber since it wouldn't fit in our other impractical car.
Luckily, kind of, I have at my disposal:
Two 75x75mm treated fence posts (intended to replace a couple of wobbly fence posts - but that'll have to wait...)
Some offcuts of interior T&G softwood cladding.
A few lengths of CLS.
I know this is not an ideal catalogue of materials - especially the interior cladding (although my 10 year old log store has a sloped roof of the exact same cladding and has survived OK after initial coating with fence paint...)
But I also plan that this isn't a permanent fixture - it's just something that is sufficient for the task of supporting a charge point and "safe" in all aspects - I'll plan or replacing it with something more appropriate maybe as early as this summer...
I did a rough sketch of an idea that I came up with:
This needs to be completed by tomorrow sunset...
If anyone has any comments on this, I'd be very grateful to read them.
Either that, or simply wish me luck!
Check that the charger is allowed to be fixed to a wooden support. It might only be able to be fixed to a non combustible surface ie brick.
Sat 18 Jan 25
What brand charger???
Many need only a single post to attach the bracket to, others may only need a small crossbar added at the top, some may need two small crossbars- there is no 'industry standard' spacing...
(usually the manufacturer has a 'mounting template' supplied, and is also often available on their websites as well as to their requirements...)
eg a Zappi
That's one of their 'pedestal mounts', but I have seen them simply screwed to a wooden carport support with a single screw at the top in the center mount hole, and two at the bottom...
But every manufacturer has their own mounting requirements- so check their website...
One thing to watch for, is that there are regs about height etc that also need to be complied with
There's also other requirements about them (minimum distance from the street or footpath etc) that also have to be met...
The Andersen mounting sizes
Installed between 0.75m – 1.2m from ground level...
Taken from https://manuals.plus/andersen/a3-de..._mount_a3_assembly_to_the_permanent_structure
Thanks for all of that.
I did intend to search for the Standards on installation height - sparky mentioned that chargers ought to be 1.0m above ground. But in the A3 this places the lidded top just a bit too high for comfortable access. I'm 6'2" so not a drama for me personally, although I did get the Mrs to test the imaginary lid and reckon that 1.0m is just a bit too much.
I'd settled on a height for the bottom of the unit at somewhere between 80 to 90cm above ground. Which falls exactly within the specs you've copied. 👍
I asked that very question when the EV charger install sparky was here to check out the layout.
Apparently fixing to a wooden fence is acceptable.
The charger itself is fine on wooden structures (although many 'suggest' a fireproof cladding' on a habitable structure but it isn't a requirement) ie if you have it on the side of the house on a wooden wall, then a sheet of 'fibro'/concrete fiber board, but as this is a standalone post, no worries...
Mostly because it isn't anything more than a 'big switch and box of electronics'- just a 'bigger fancier version of your phone charger'...
Many have them fitted on a wooden fence, just on one of the posts... (you can even clip the armoured cable to the fence itself as that is considered a 'permanent structure'
Cheers mate.
The cable is indeed intended to be cleated to the bottom rail of the partition fence (y)
One thing to check- hows your wifi connection signal strength there where the chargers going???? if it's weak there, commissioning will take forever (when its first hooked up, it will want to do its updates etc, and a weak wifi signal will slow it down considerably...)
If you want more time to do it, and aren't doing 200 miles a day, you should be fine using the "granny charger" to charge for a few weeks. Most cars will come with one, and it can run from any normal socket. Or an extension lead if you are lucky (they are only 10 amps).
When our EV arrived, we used the granny charger at first, until we worked out the best place for the EV charger.
Many chargers will also be happy fixed to a substantial post e.g. 8x8 gatepost.
PS from your username, was it a Chimaera? I used to have a 500...
I'm hoping that WiFi will be pretty good there. Fingers crossed. The main router is not far from the patio doors seen in an above photo - around 10 meters, and there's also a slave mesh transmitter "closer" on the first floor in the room at the closest corner of the house.
The box arrived yesterday. I've had the front facia off and the "tested" sticker inside the unit is dated 9 Jan 25. Hoping that little to no update is required...
Could you fix it to the carport upright with a couple of cross members to match the fixing holes.
It would be under cover then as well.🤔
I did give that a serious consider - measured everything up, etc.
However, I think that the car is too wide for easy access to a charger tucked in there - since I need to park the car off centre - closer to the garden fence side, so I can have unrestricted access to the shed and micro-workshop that I've set up in there.
(Another thing that put me off a bit was having to purchase an extra 5 metres of SWA cable (with integrated cat5e ) at around £8 a metre. The £200 I already spent on 24 metres was painful enough!)
I've also got an idea for a little roof addition for the charger and plinth combo that "mirrors" the roof design of my self-made car port.
