That's the plinth erected, first coat of protection, complete with fix point template including rear strengthening spars.
That's the "emergency" build complete, the rest can be seen to in slow time.
The Jack Russell is named Mouse.
You can check the wifi signal using your phone- just hold it near where the charger is to be mounted and check what signal the wifi is getting on the display...I'm hoping that WiFi will be pretty good there. Fingers crossed. The main router is not far from the patio doors seen in an above photo - around 10 meters, and there's also a slave mesh transmitter "closer" on the first floor in the room at the closest corner of the house.
The box arrived yesterday. I've had the front facia off and the "tested" sticker inside the unit is dated 9 Jan 25. Hoping that little to no update is required...
Something you might like to think about as you said you may put something over the top, I made a Church noticeboard once, the sloping overhanging “roof” was made from slates on a board bonded together and between with black CT1.
Still standing years later.
Ian
