Elf'n'Safety madness
The last kettle I bought was a robust catering one - the instruction booklet is small and mostly consists of a labelled diagram with part numbers showing so you can re-order parts to repair the thing should it go wrong. There may have been a short section on electrical safety, and a warning of minimum and maximum fill amounts, but that is all. The kettle is still going strong after 3 years - which is great. My last 4 electric kettles (which ranged in price from a cheap supermarket special to a very expensive branded version) all failed after about 18 months - and all the same way, they all sprang leaks - 3 of them around the little window that shows how much water there is in the thing and the 4th (which I deliberately chose as it had no window) sprang a leak under the spout :-(
Regarding instuction books, I find nearly all modern ones almost useless. As Mike says they usually have pages and pages of safety instructions (often in multiple languages) which are just to cover *** and contain very little useful information to the user, Any real informtaion is is usually hard to understand as it is often a poor translation from the Chinese :-( Exploded diagrams are often so small as to be illegible, and photos are often printed so poorly they are impossible to decipher.
I had these same thoughts when i bought one recently....
Seriously, if you dont know this already, perhaps you should be supervised by an adult :roll:
    36.8 KB
Regrettably, this is the case not only with small, simple items, but even with major machinery. Unless I need to know a part number, the manual is usually the last place I'll look in case of a problem. Even on my 3 phase Rojek p/t the 'Instruction Manual' is virtually useless.
The atrocious English is usually good for a laugh though - pretty much the only purpose the manual actually serves!
