The blade or more specifically the arbor doesn’t seem to be parallel with the table any more, with all the attendant problems that brings. I tried measuring with two different blades fitted and measured about .7 to .8mm discrepancy across the 200mm blade. Does anyone know if you can adjust the motor assembly relative to the table, I’ve had a cursory poke around but haven’t found anything definitive. Thanks for any hints or guidance.
