Elektra Beckum pk200 issue
wolfrace
4 May 2021
Yorkshire
The blade or more specifically the arbor doesn’t seem to be parallel with the table any more, with all the attendant problems that brings. I tried measuring with two different blades fitted and measured about .7 to .8mm discrepancy across the 200mm blade. Does anyone know if you can adjust the motor assembly relative to the table, I’ve had a cursory poke around but haven’t found anything definitive. Thanks for any hints or guidance.
Thanks for that, he mentions the out of parallel issue, how it’s a pain to sort but not how to sort, though it must be doable. I had a look underneath and there are a load of hex head bolts to play with but I’m not sure which ones hold the key and I’m quite anxious for the motor not to fall out while in use! More investigation required I think.
