Wizer":2ex82rle said:P/T (in post )
OLD":3jv78ur0 said:Not correct yet you need a rcd (2 ways) then the mcbs (1 way each) davy_owen_88 post has the info for cct requirements the price looks typical though. If your not sure list what you need to feed.
Just found toolstation 71165 10 way split load box with lots of mcbs page 219 £38.98 easy to convert to non split load if you need all the ways and extra mcbs at £2.48 each
Roger Sinden":2q7fz0bf said:WiZeR - with my chargers, I had some spare room underneath one of my mobile units and installed a glorified distribution board to feed all my chargers individually via their own dedicated switched circuit. I simply connected some old 13Amp switched double sockets in a line behind the chargers and plugged each charger into one of the sockets. Just turn on the charger you want to use.
As a slight aside, when I wired up my workshop (in 2002 so no part P here thanks) I installed a separate ring that was switched by a contactor. The sockets were fixed fused outlets (ie not 13 Amp) as the ring was intended to feed small heaters around the perimeter of the workshop. A room thermostat was going to turn the contactor (and hence the heaters) on/off. I never implemented the heaters but now have a spare ring from which I can hang off any 16Amp machines. I replaced a few of the fused outlets with the blue Commando sockets.
WiZeR":klz1ujme said:Roger I like both those ideas. Thanks. My Dad did my Garage in 2002 too, so no Part P![]()
WiZeR":daexsdcv said:My Dad did my Garage in 2002 too, so no Part P![]()
davy_owen_88":8ifn10pb said:WiZeR":8ifn10pb said:My Dad did my Garage in 2002 too, so no Part P![]()
Tut tut... :wink:
WiZeR":z6x2i88p said:Getting there slowly.
on TLC we have
MK 5512 12 Way Metal Enclosure - for up to 10 MCB s
MK 5906 6 Amp MCB x2
MK 5932 32 Amp MCB x2
MK 5916 16 Amp MCB x2
MK 5544 Blank for Sentry Boards x2
http://www.tlc-direct.co.uk/Products/MK5512.html
Am I wrong or am I right ?
