Hi
Have dug a trench 750mm deep, 25 metres from house consumer box to shed. Laid in the 10mm armoured cable, protected it and placed warning tape, not filled in as it needs to be seen that I have complied with the requirements of part P. Now need to get the old consumer box (fusewire type) replaced with a modern split board. I have six double sockets (metal) to install (think I will increase to 10 on the principle you can't have too many) and have 4x6ft low energy florescent tubes to fit. The shed has an Apex roof, what do you consider the best way to hang the florescent tubes? I am going to have a garage consumer box in the shed, this will limit me to 40amps, probably a 16 and a 6amp mcb, any thoughts on this, eg should I go for a 6way consumer box? Is there a specific type of board that the consumer unit should be placed on? (the one in my garage seems to be a piece of blockboard with porcelain/ceramic spacers behind). Already phoned 4 electricians who advertise as Part P but not received any response, one who was not qualified said it goes mad at this time of year.
Cheers Con
Cheers Con
