chrispuzzle
Here is my latest puzzle. This has been a minor disaster but a good learning curve! The problems all stem from using, for the first time, a 3mm light plywood of the sort used for r/c aircraft models. This cut so easily that I felt I had very little control using FD puzzle blades, and after a while I switched to a "Yellow Label" Niqua 2/0 which is much less aggressive.
The wood snapped once or twice across narrow parts when cutting - the blade lifted the wood and it tore. I had to hold it down firmly very close to the blade when drawing towards the end of a cut.
So there were a couple of tears where the underside of a piece got damaged and the original idea for the piece became two rather smaller pieces. Other than that, it's still a beautiful picture, taken from a calendar. 196 pieces, a little less than 12"x12".
Here are the figurals. The bear is in two pieces - the witch is too, but accidentally! I cut through the head of the broomstick...
Chris
Chris
